Caribou
Jan 06, 2015Explorer
hmmm, Wizard, you confused me there, sorry. The manometer would show the inches of water column. If the demand regulator should reduce the pressure coming from the propane regulator then the water column should be greatly reduced coming out of the demand regulator. If the water column coming from the demand regulator is close to the 11" coming from the propane regulator then I have a problem. Am I thinking about that right?
