MrWizard
Jan 06, 2015Moderator
yes...
but the test has to be done while cranking the engine
there is NO engine vacuum, if the engine is not turning
you already stated, every thing on the system is fine, unless the Onan is running or trying to run
means the on demand regulator will not show a problem, unless the fuel solenoid is open and the engine cranking
