DrewE
Aug 28, 2019Explorer III
ADAD437 wrote:
didn't check model, but not like yours.filter screws in on side and hard to get to, wondering if fuel will siphon from tank if line disconeticded from filter?
That probably depends mainly on how high your generator is in relation to the fuel tank.
One sure way to prevent siphoning fuel is to do the work when the fuel level in the tank is below about a quarter tank, and so lower than the generator pickup. At worse you'd drain the (relatively) small amount of fuel in the line between the tank and the generator.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
