enblethen
Sep 22, 2020Nomad
No, it is time to remove the bowl, see if float is left in bowl or still attached to body with small pin.
It is possible as other poster stated that debris could be in line or between needle and seat.
You could carefully remove pin, float and needle. Spray brake clean or carb cleaner into opening. With needle removed, crank over genset to check for fuel flow into bowl.
A good small engine (lawn mower) shop can go through carb.
