RVDisney's avatar
RVDisney
Onan 4000 Revs up and Down
I have been having issue with my generator, onan microlite 4000. Has gas fuel pump works spark plug new filters are good. Took the carb off and it is clean. Nothing gummed in bowl or jets from what I saw. However, I get it going and all it does is rev up and down?
Is the carb needing replaced or is something else up with it?
    How many hrs. on it.
  • Hook up the fuel supply line to a gas can with a can of Seafoam cleaner in it....run the genny for a half hour and then shut it off and let it sit overnight.....the next morning run and if the "Hunting" or "Lean roll" is gone.....rehook up the fuel supply line.....if not the carb will need to be rebuilt.......
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
