j-d
May 17, 2015Explorer II
It's a flat sheet metal plate with the two tops of a V-shaped wing-nut bracket spot welded to it. Filter wing-nut screw extends from bottom of the V. What/Where is it broken? I haven't had ours out, but I know it's miserable access and doubt it could be welded in place because of all the plastic shrouding around it. Not to mention the gasoline nearby in the carburetor. I'm sure it could be brazed or re-welded, but it can't warp or interfere with Filter on one side and Carburetor on the other. Or it'll leak air and let dirt into the engine. For those reasons, my guess'd be...Replace.
An epoxy repair like JBWeld might work, but again, if it doesn't you've got dirt entering your genny's engine...Replace.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
