- pnicholsExplorer IIThe Onan spec sheet here:
https://powersuite.cummins.com/PS5/PS5Content/SiteContent/en/Binary_Asset/pdf/Consumer/specsheets/a-1399.pdf
says it should burn 0.5 Gal/hr at half load (putting out 16.65 amps) and 0.7 Gal/hr at full load (putting out 33.3 amps).
Just as reference, this "roughly" means that it will run your air conditioner for about 2 hours on one gallon of gas. - Triker33ExplorerIt's true that it will use .3 gal/hr, no load to .8 gal/hr full load.
No matter what model/Series it is. - coolbreeze01ExplorerFigure a gallon an hour. It will burn that or less :C
- TEXASExplorerNot true for all units. This is why we need to know what unit.
- Chum_leeExplorerrvten wrote: "Not enough to worry over."
Unless you are below about 1/4 tank on gasoline.
From the factory owners manual for Onan 4 kw 60 HZ gas gennys:
.3 gal/hr, no load
.5 gal/hr half load
.7 gal/hr full load
From the factory owners manual for Onan 4 kw 60 HZ LPG gennys:
.4 gal/hr no load
.6 gal/hr half load
.7 gal/hr full load
for 50 hz gennys, slightly less.
Chum lee - rvtenExplorerNot enough to worry over
- gmctoymanExplorerPropane, or gasoline?
- TEXASExplorerA 4K what. BF,BFA,CCK,KY, Series P. Really helps to know what you have.
- harold1946ExplorerAround 3/4 gallon an hour under full load.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
