Alright I've got an Onan MicroQuiet 4000 and I need to adjust the valves. The model # is 4KYFA26100B Anyone know how it's turned over by hand to get the piston TDC prior to lash check. Will it tur...
Here’s your parts manual. Look for spec b parts. Your valves will be side by side . The one closest to the muffler is your exhaust valve. Sometimes you can save the gasket after taking the screws out if the cover is stuck tap on it a little bit. https://www.dropbox.com/s/hzj5ospf1wajbn9/0981-0246_I35_201706kyparts.pdf?dl=0
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
