udidwht
May 01, 2018Explorer
Onan 4K gen?
Alright I've got an Onan MicroQuiet 4000 and I need to adjust the valves. The model # is 4KYFA26100B Anyone know how it's turned over by hand to get the piston TDC prior to lash check. Will it tur...
road-runner wrote:udidwht wrote:I'd guess that when one valve is fully open you can be sure that the other is fully closed, so you don't have to worry about finding TDC. The service manual specs say the lash is 0.002, and the clearances sections gives the range as 0.0008 to 0.0032. It says to adjust both at TDC when they are both fully closed.Kpackpackkelley wrote:
Open intake all the way open and set exhaust valve .003 then rotate till exhaust is all the way open and set intake .003 on that model. But first check your setting before you move anything.
Any reason not to adjust them when both valves are closed?
.003 is the lash for both valves (stone cold)?
