I have a four winds with an onan 4 K gen. that I use maybe once a year. It is always a pain trying to un-gum it when I need to use it because the gas goes bad in-between uses. Should I drain the float...
What I did on one of our past mh. I added switch on the electric fuel pump that's on the generator, and when I knew that we were not to use it for a while, I would turn the fuel pump off and let the generator run out of gas, which empty the carburetor.
Dusty
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
