I have a four winds with an onan 4 K gen. that I use maybe once a year. It is always a pain trying to un-gum it when I need to use it because the gas goes bad in-between uses. Should I drain the float...
use non-ethanol based fuel. Pump will say it. Why? Pure gasoline, more expensive these days, lasts longer and does not gum up the carb -- unless left for years.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
