RhigleyExplorerJun 29, 2021onan 4k genmy gen. will run without load for about 45 seconds then will hunt 2 times than run smooth again for a 45 more seconds again. When I put a load on it (1500 BTU AC) it will do the same but not as often....Show More
GdetrailerExplorer IIIJun 29, 2021Gasoline?If so, hunting is typically too lean of a mixture which would indicate a plugged carb jet or not enough fuel in the carb bowl.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
