my gen. will run without load for about 45 seconds then will hunt 2 times than run smooth again for a 45 more seconds again. When I put a load on it (1500 BTU AC) it will do the same but not as often....
I only have about 60 hours on it. I'll replace fuel filter and see if that dose anything. I know when I prime it a lot of gas is moving because I have had the bowl drain open and the container I use under the bowl fills quick. I'll try to remove the bowl and take a look. Thanks
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
