dugarug1's avatar
dugarug1
onan 4k generator stopped
learn alot here every day, so here is my problem.
1995 class-c, 4000 onan gen, 556 hours, serviced regularly, oil is clean and full.
running my ac by the gen, after five minutes it stopped.
the gen will start by either the inside or outside start buttons, runs as long as buttons are pushed, stops when released, my electric meter stays in the red showing no electric power,
suggested it might be a stator.
any ideas greatly appreaciated
Doug
  • Onan uses a LATCHING RELAY that keeps power going to the fuel pump and ignition. This system is BYPASSED when the starter is spinning. A bad low oil switch or other safety SWITCH FAULT can cause these symptoms, a bad latching relay or connectors. You need to troubleshoot.
  • could be a gen issue. The manual says slip rings, brushes a possibility. I'd take it to cummins
  • Mine runs fine as long as the start
    Button is held in. Don't think carb.
    Anything else scares me.
    Could it be a loose connection?
  • Mine would start but die when the start button was released. Carb was varnished and when the choke would pull the throttle all the way open it would stick, over rev and shut itself off due to high rpm & voltage. Cummins diagnosed it, replaced carb $433 out the door. Very pleased with their service. Only charged me 1 hr labor for diag & R&R. Those little carbs are pricey. $285.00. Good luck. I should have done a better job. This thing sat for 4 yrs prior to me buying it. Now it's Seafoam every fill along with staybil.
    They said it was scheduled with the tech @ 2pm and I picked it up @ 3. Can't complain about that. This was @ Cummins Rocky Mtn in Phoenix.
  • Mine does the same thing. Got a app
    With a Onan dealer. Will know then.
    They told me it is a symptom of no
    Power.
  • Sounds like your fuel filter is plugged. Or, maybe your fuel tank is at 1/4 and it's trying to slurp what fuel it can.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
