jayhorowitz
Apr 08, 2015Explorer
64thunderbolt wrote:
4KY has an oil filter? Have never seen one on the ones I have had. Did you use the correct wgt oil?
on one of the pics I see some seepage on one of the rocker cover bolts but the oil on the breather tube looks normal. Is it leaking @ the drain plug?
I didn't see any leaking at the drain plug but I'll double check again tomorrow. Given the amount of oil I've put in this thing, if a drain plug leak is the issue I'd expect to see a solid puddle of oil when I open the access flap. We'll see...
I don't know what the rocker is or what its cover bolts are. Can you explain? Is that something which might just need to be tightened? Thank you for your help.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
