Kpackpackkelley
Apr 16, 2015Explorer II
You need to find a good small engine mechànic to tighten all the gaskets around the carb , air filter housing , and head. Gasket to spec and then set the valves to spec.
If it's not cold weather run 30 wt oil as the manual specs.
If you need the service manual pm me your email and the complete model number.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
