jayhorowitz
Apr 17, 2015Explorer
427435 wrote:jayhorowitz wrote:
Thanks for bringing the thread back toward the oil consumption issue :-)
Toward the end of this weekend I hope to have the opportunity to inspect the breather valve. After that - particularly lf it doesn't solve the problem - I'll try and find a good small engine mechanic who can take a look at some of the other suggestions here. Unfortunately I'm in Snowflake, Arizona now so my options are a bit limited, but I'll be headed toward Albuquerque in a few weeks and may have time for a trip to Show-Low, AZ in between.
Is is safe to continue occasional use of my generator while the high oil consumption issue is outstanding? (Adding oil as needed, of course.)
Again, are you screwing the dip stick fully in and then removing it to check oil level??
Yes, I am.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
