Clay_L
Mar 12, 2013Explorer
I had a similar problem and found I could keep it running (rough) by holding the choke closed. After doing that for a while it started running okay. I guess the varnish in the carb got cleaned out.
Other folks have suggested running a hose from the input side of the fuel filter to a container of gasoline with Seafoam mixed in and running it to clean the carb out.
I think the container may need to be elevated to the same height as the filter so the pump can pick it up.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
