Kpackpackkelley
Mar 13, 2013Explorer II
Take your mutimeter and set for ac plug your leads into electrical outlet in the trailer while cranking to verify 120 or a lamp or anything just make sure your on gen power not shore power just unscrew that solenoid to check it but this sounds like the board you may have to take it out and send it to flight systems to verify its good another thing you may try is using this contact cleaner on every plug in that goes to the board and start switch Theres a http://www.radioshack.com/product/index.jsp?productId=2104746 lot of little prongs in all the plugs mex posted this cleaner the other day said its really good I'm going to get some myself
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
