normared
Oct 07, 2013Explorer
romantraveler writes: "I had exactly the same problem and got the same code. The technician said it was probably the control board or slip rings. Turned out to be the slip rings. $410.00 later it runs like a champ. Good luck. RT"
More often than not, trouble code 32 has nothing to do with low voltage, carb, or anything else. It is almost always trouble with either the voltage regulator or the slip rings / brushes. What RT posted is exactly what ours was...
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
