carterw65's avatar
carterw65
Onan 5.5HGJAB-1038C
Hi all, I am new here.
I have an Onan HGJAB-1038C Spec C generator that is surging while under a load from the A/C. It will do this for a minute or two then die.
I just replaced the carb and camping world said the choke wasn't adjusted properly. I don't think they put it under a load though because it was cold out.
It runs great not under a load and will start right back up after it dies as long as there is no load on it.
I put a temporary fuel line into a fuel jug to see if I had problems with fuel flow from the tank. I checked other things as well and from what I can tell it is not a fuel delivery problem. I also made sure the oil is right up by the full mark.
Not sure where to go from here other than back to camping world, but that is expensive sometimes.
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
