Ed_Gee
Jan 02, 2020Explorer II
Team Roper Heeler wrote:
My wife and I will be heading west in September. Overnighting around 9000'. What do I need to address to insure optimum performance. We currently live around 1,500'. Thanks for the help.
Gasoline powered generators do have a carburetor altitude adjustment,,,if you have a gasser....
Effects Of High Altitude And Extreme
Temperatures
If you travel at high altitudes or in extreme temperatures, your generator can lose power. In such lower-density air conditions, you can’t operate as many electrical devices as you could under normal operating conditions.
Power decreases 3.5% for each 1,000 feet above an altitude of 500 feet. For example, to operate at 4,500 feet (4,000 feet above rated generator altitude) multiply 3.5% x 4 (4,000 ft) = 14% power loss. Then multiply .14 x your generator’s power rating: 4,000 watts x .14 = a loss of 560 watts at that altitude.
Power decreases in extreme temperatures by 1% for each 10° F (5.5° C) above 85° F (29.4°C).
NOTE: The carburetor on a non-EFI gasoline generator may require adjustment at high altitudes. (See your Operator’s Manual or your Cummins Onan Authorized RV Service and Parts Dealer.)
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
