mlts22
Jun 10, 2013Explorer II
B Traveler wrote:
If your next rig is a "B" similar to mine, you won't need another generator, just an inverter, to charge cell phones or to watch TV, and you don't need either to run the furnace. Those things will not run down the house batteries for several days, and driving will recharge them. I do have an small inverter.
The biggest battery drain I tend to have is the furnace, namely the furnace fans. In my experience, the furnace uses about 7-10 amp-hours, (and this seems to be independent of BTU). So, if I have two house batteries (either two 6V jars in series, or two 12VDC in parallel), I'm looking at two nights max before I cross under the 50% point which isn't good for the bank (either the battery bank, or the wallet when I have to replace them.)
To offset this, most Bs use a 45 amp converter. So, I'll be pulling at most 550-600 watts from a generator to charge up the bank. With this in mind, pulling out a 1000 watt red/blue that can run a good long while on less than a gallon of gas is probably the most economical way of recharging the batteries when I boondock. Since a generator is the most economical at a half load, running a 1000 watt model for four hours will get the house batteries up enough to withstand another day of worst case furnace use.
I could be wrong on these numbers though.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
