185EZ
Aug 15, 2019Explorer
seafoam doesn't fix problems
Seafoam contains kerosene, which is paraffin, which we all know as wax
Anything more than the recommended dose and it will cause more problems.
I doubt it's tight valve lash IF it ran fine for the first 100 hours
You replaced both spark plugs and then you replaced another because it wasn't firing?
Was the porcelain black?
If so you may have a running rich issue.
Can you see that the choke plate is fully open when hot?
Could be a spark plug wire
Need more info
Need more info
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
