Pirate1's avatar
Pirate1
Onan 5500 EFI vs Carb.
Seems all I hear about is carb problems with the Onan's. Is the carb model standard vs EFI? Never seem to read about any issues regarding the EFI model. Is the EFI worth the extra money or just more to break? More fuel efficient?
  • If I was given the option of EFI vs. carb I'd take the EFI. I'd be the early adopter (early adopter EFI 2015?). For me the advantages would be less or no clogging issues and any decent implementation would have automatic altitude compensation. It should start easier when cold. Fuel economy-not much different unless the carb setting was way off for elevation.
    I've had several small engine EFI systems in the last 5 years which ran flawlessly.
    You're running a risk of early kinks. Fuel hose configuration is something you should check and weigh in decision.
  • Since my post I have found a couple of comments that perhaps the EFI requires a return fuel line to tank so if it isn't installed, I'm guessing that would mean tank drop too.
  • Something to chew on...
    Maybe there's too few EFI units out there to expect reliable feedback...
  • I don't know the answer to your question.
    The original Onan 5500 in our 96 Southwind works great.
    I had one small problem a couple years ago, a new fuel filter solved the problem
    I use Sta-bil in the fuel and exercise the generator every month or two.
    I think taking care of the generator is the most important thing you can do.
    If you don't take proper care of an EFI unit, I'm guessing you'll have problems.
    I'm satisfied with a carb, at least for now.
    JMO :)
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
