wa8yxm
Aug 18, 2019Explorer III
YOu say it primes and runs. then it stops and won't prime. then it primes and runs, then it stops and won't prime.
The fuel pickup in the tank has a strainer (pre-strainer) just like the water pump has. If you've left old gas in the tank (Gasser) or algae has grown (Diesel) that pre-strainer may be clogged.
Then there is the fuel filter it too can clog
And a pinched fuel line not letting fuel through.
all of those will act exactly as you have described Error code will show "No fuel".
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
