dougrainer
Aug 20, 2019Nomad
wa8yxm wrote:
YOu say it primes and runs. then it stops and won't prime. then it primes and runs, then it stops and won't prime.
The fuel pickup in the tank has a strainer (pre-strainer) just like the water pump has. If you've left old gas in the tank (Gasser) or algae has grown (Diesel) that pre-strainer may be clogged.
Then there is the fuel filter it too can clog
And a pinched fuel line not letting fuel through.
all of those will act exactly as you have described Error code will show "No fuel".
A Genset fuel pick up in the fuel tank is just a straight metal tube that is terminates right at the 1/4 tank level of the fuel tank. NO filter or strainer at all. Diesel and Gas are the same. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
