Sam_Spade
Mar 26, 2016Explorer
MrWizard wrote:
Al
try shutting off the breaker to the converter
i suspect the interference is RF noise from the converter electronics
its a simple test to help isolate possible problems
improper/bad ground on the converter or maybe the transfer switch, could allow RF noise, when on the Onan that doesn't happen when on shore power
+1 on both of these ideas.
Having a monitor on the AC power might be helpful too.....to see what the voltage IS when the washer acts up.
A cheap transistor radio set to an empty spot on the AM dial makes an excellent noise/bad-connection locator.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
