dcg9381
Mar 26, 2016Explorer
Not enough info.
Generator shutting down?
These lights - on the washer or the generator?
Is it the dry cycle that's having problems? Anything else on?
At high altitudes, say 10k expect the genset to lose 25%-30% of rated capacity. You can actually get some of it back by changing the altitude setting on the carb...
Need more info to steer you the right way. Static @ sound bar is an indication of an improper ground somewhere.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
