dougrainer
Dec 04, 2014Nomad
NO RV Genset outputs 220. You CAN rewire some of them to output 220, but from Onan, they are ALL 120 output. Verify that at the transfer switch the each of the 2 HOT legs from the APU have 120 to the Neutral. If you have bthat then the APU wiring to the transfer is good. Then check the output wiring at the Transfer box. BOTH Hot legs to neutral should show 120. IF NOT, then your transfer switch is bad. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
