dougrainer
Jul 23, 2016Nomad
stro1965 wrote:westend wrote:
Checked your oil level?
I have not. Will do.
MOST common problem when a genset stops in transit but runs fine parked. Low oil causes the oil pressure switch to activate due to the low oil level. When you stop or turn the low oil moves to one side of the crankcase and causes the Pressure Switch to momentarily lose oil pressure. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
