roadrat57's avatar
roadrat57
Onan 5500
Question, can gas fuel additive have an adverse affect to generator performance?
Changed oil and air filter. Added fuel additive to gas tank. Generator ran great before these things were done. It now starts, runs then quits running. Sometimes it runs for a few minutes then quits and other times it will run for 10-15 before it quits.
Any suggestions would be greatly appreciated.
Thanks
  • Did you double check your oil level? Some gen sets have a low oil shut down. If your oil is slightly low it will shut down like you describe.
  • roadrat57 wrote:
    I do have a new gas filter. Maybe I'll put it in.
    Try a new fuel filter and let us know. The Onan 5500 on our 96 Southwind was surging and running rough.
    A new fuel filter took care of the problem.
    I use Sta-bil Marine in the fuel tank, no problems.
    Your generator only has 100 hours but, how old is it?
  • I still think it's the fuel additive. Added to 25 gallons of fuel which is the recommended gallons for entire bottle of additive.
  • Did not install new gas filter. Gen only has 100 hours. Did not require change per manual.
  • Could there be an air leak from the new fuel filter install?
    Bill
  • Sounds like what ever you added loosened up "crud" in the tank and it is now being sucked into the carburetor.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
