smithrock's avatar
smithrock
Onan 6.5 genset problem
Yes I know this isn't technically an RV issue :B. But I'm looking at a boat with an Onan 6.5 gas generator, problem with the generator is initially it runs fine for 45min or so. Then you shut it off- and it doesn't want to start:h
Sellers are telling me that it's been sitting or the gas is bad and it needs to run through it. I'm thinking it's something else since the boats engines seem run fine off it. If the carb is varnished and gummed up, it's not gonna fix itself It wouldn't run initially if it were gummed up. Any ideas on what to check?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
