turbojimmy's avatar
turbojimmy
Onan 6.5NH-RV Running Rough
I posted this in the smokstak forums, but it can't hurt to ask the experts here, too.
1984 vintage Onan 6.5NH-RV. Came with the RV. It had sat for about 6 years when I got it. I changed the plugs and ran some sea foam through it and it's been fine for about 3 years.
Back in June while boondocking at the Pocono Raceway I needed to rely on it when my fridge stopped working on propane. It ran fine for around 10-12 hours when it began doing this:
https://youtu.be/anUuXifEvQ0
Runs rough, comes close to stalling (sometimes does stall), backfires through the exhaust occasionally.
It smells rich but there's no black smoke. Choke is pulling off just fine. I took the carb off and cleaned a piece of junk that was stuck in the needle seat. I was SURE that was the problem. Put it back together this morning and it does the same thing.
New points and condenser are on the way, but it seems like fuel?
Ideas?
  • romore wrote:
    Did you thoroughly clean the small passages in the carburetor and change the fuel filter?
    Fuel filter is new, but I did not clean the small passages in the carb. I sprayed the bowl with carb cleaner because there was junk in there.
    How do I clean the small passages in the carb? I can take it back off again - I'm getting good at it now!
  • Did you thoroughly clean the small passages in the carburetor and change the fuel filter?
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: May 04, 2025
