Carmanracing's avatar
Carmanracing
Onan 7000 Generator overheating/shutoff help!!!
Model no. 7HGJAB -900D
Cummins Onan RV QG 7000
Our generator will run for several hours, shut-off, cool down then restart, run less time, shut-off then cool down and start again, run even less then etc....
When it shuts down it gets no spark but when it cools down it restarts.
It has about 3000 hours.
Any suggestions???
1 Reply
  • Air cooled or water cooled?
    Try cleaning it once it is completely cool (like overnight).
    A high pressure cleaner will probably work well. If water cooled, it is easy to find that the radiator is dirty, and might be covered with oil or something. Air cooled can also be coated with some oil mist too, and this collects dust that will insulate the metal from the heat.
    3000 hours is a long time, and even some small amount of oil mist would collect a lot of baked on dirt and insulate the cooling fins from the air going over it to cool the generator.
    Also check to see if you might have picked up a plastic bag, or other trash on the air intake to the generator. .
    Fred.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
