KendallP's avatar
KendallP
Onan BFA Oil - Why not 20W-50?
Note: Our typical camping climate range runs from 10F to 115F (if we go to Redding, CA in the summer... otherwise up to about 105 in Southern Oregon.)
Clearly Onan/Cummins have updated their recommendations for the old BFA. Whereas they once recommended 30W only, they now have a chart with several recommendations for different temp ranges with a nod to 15W-40 (I'm currently using) for the widest ranges. But no mention of 20W-50. And my searches (though they do show some guys running 20W-50 with no problems and some with) turn up little mention either. Why?
Now I know that 20W-50 is not a perfect 20 nor a perfect 50 for their prospective temp ratings, but it still seems that if 30W worked back in the day, that 20W at cold temps is better than 30W and 50W on a hot day is better than 30W.
The only thing that I can reckon is that a good 30W is... pretty much always a 30W and doesn't break down to anything less. But that shouldn't be an issue to anyone who changes their multi-weight oil often enough.
Now theoretically, other than the potential for thermal breakdown in time or overheating, a 10W-30 should act the same as a straight 30 at 212F. So why the difference in the chart below?
The reason I even ask is I run 20W-50 in the 454 (another conversation) and I wouldn't mind just keeping one spare oil type aboard.
The only other thing I can figure is that Onan would prefer the lower resistance for the little 2 banger to better lubrication. When I get a chance... I'll ask 'em.
Your thoughts?
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
