otrfun
Jul 22, 2016Explorer II
Your logic sounds good to me.
However, if you call Onan, IMO the chances of getting an actual Onan engineer to commit to a debate on the pros and cons of using 30w vs. 20w-50 is highly unlikely. More than likely you'll never get farther than the typical technical support rep who doesn't have the necessary engineering background to authorize a deviation from the guidelines established in the owner's manual.
If your Onan is under warranty and you're operating in ambient temps above 100 degrees, 30w is the only way to go---if you want to keep your warranty intact.
If your Onan is not under warranty, and you're willing to take the risk, then give 20w-50 a try. If it doesn't sieze or blow-up, get an oil analysis and go from there.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
