KendallP
Jul 22, 2016Explorer
Son of Norway wrote:
Have you tried the 20W-50 in your onan yet? I tried a multi-weight oil in my Emerald 3 6.5 once and found that it burned through way too much oil. I do not recall which multi-weight oil I tried, however, and I did try it during the summer.
Miles
No.
Been using 15W-40 for the last several years. I can say that she does burn through a bit of oil, but I can't recall whether or not she did with just straight 30.
Overall she runs well. But when it's hot, if I shudder' down for a bit, she won't exactly clamor at the thought of starting up again. Though she will fire up again eventually. But that was the case with straight 30 too.
It's important to keep in mind that she'll run the overhead A/C for hours with the mercury up and over a hundred and only stop when I hit the kill switch.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
