CharlesinGA
Aug 16, 2016Explorer
To clarify one thing that non-aviation people may not understand. Aircraft oils are referenced by GRADES, and by WEIGHTS.
When MEX mentioned Aeroshell 80, 100 or 120 Those are GRADES, and that number is TWICE the WEIGHT of the oil. Thus he was referring to 40,50, and 60 WEIGHT oils. 60 weight is almost exclusively used in radial engines. In small aircraft horizontally opposed engines, 50 weight is most common, however small 4 and 6 cylinder Continental engines, the 75/85/90/100 hp four cylinders, and the 125/145 six cylinders should not be operated on 50 weight as ring problems will occur.
Charles
Charles
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
