rtbmrgl's avatar
rtbmrgl
Onan gen, solar charge voltage
Hello,
I have a two part question,
1-what is a good charge cut off voltage for solar charger,
I have wet filled batteries and 2-100w panels, it's now set at
13.8v
2-my battery went very low, (refer was on DC at night by mistake)
The battery voltage dropped to about 10-10.5 v, the generator
started and ran as long as I pushed the start button, it stayed running but when released it stopped running. The orange light on the switch did not come. When the generator
is running and charging the orange switch light is on. Once the solar brought the batteries up a little the generator worked normally.
I have a onboard Onan 2500, AF-990.
Thanks Mark
Roseville, Ca
  • westend wrote:
    13.8 V for the solar voltage limit is too low.
    Probably but it really depends on whether he has a smart controller or just a voltage limiter.
  • 13.8 V for the solar voltage limit is too low. You don't state the type, amount, and capacity of your batteries but a typical arrangement of two 12 V batteries will not be fully charged in a day of typical use with the 13.8 V limit. FWIW, my programmable controller is set at 14.6 V for daily bulk and absorption charging and the float is set at 13.6V. The controller charge is temperature compensated so voltage will swing off those numbers in the seasons.
    Your generator problem can be one of a number of things. I'd suggest to search the Forum for that starting problem as it has been addressed many times.
  • Regarding question 2, the generator needs 12V power in to operate; the battery provide excitation power for the field (and to run the generator controls). If it's not getting enough power or detects any of various other problems, it shuts down. Many of the fault checks are disabled while the start switch is held in.
    If this is a motorhome, you probably could have started the main engine so that the alternator charges the house battery and whatever battery isolator system you have engages, and then started the generator. Once it is running and the converter providing 12V power, it likely would have enough voltage to keep going and operating (and you could then shut down the main engine).
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
