latoky's avatar
latoky
Onan Generator Oil Filter Crossthreaded
Hi!
According to my service technicians my generator is leaking oil (and can’t even run) because the area you screw the filter into has been cross threaded/stripped. They say the entire bottom plate has to be replaced to the tune of $2400. I have the Compass Platinum Protection plan and I anticipated paying the deductible. But they’re telling me this is considered physical damage and therefore not covered.
Has anyone run into this? I know coverage companies do everything they can not to pay out, but this seems unreasonable. Our RV has 15,000 miles on it. Generator has 600 hours of use. Oil has been changed ever 100 hours with Onan Filters.
Thanks for any advice on how to approach Compass and get this covered.
  • rjstractor wrote:
    I think your service department screwed up royally and are trying to make you pay for it. If the previous servicer had cross threaded the filter boss, your filter would have probably leaked.
    Yes! And, IME, it would have probably leaked from the moment oil pressure/volume was initially supplied by the oil pump.
    The OP doesn't state which model (age/current hours/size/fuel type) of Onan generator they are speaking about which would be helpful in getting more useful information in this format.
    Chum lee
  • 1. I would attempt another filter. It IS possible that the new filter is wrong or has damaged threads. IF the old filter was cross threaded, then it would have leaked. ALSO, if old was cross threaded and FORCED to mate to the old housing block, it would have taken a large force with pliers to unscrew it. THAT should have alerted the existing so called tech that something was wrong and they then notify you.
    2. I have almost 45 years of servicing Onans and have NEVER come across such a problem. NEVER!
    3. As to your ESC, ESC's ONLY cover covered parts that BREAK, not parts that have been damaged by a service technician or customer. Doug
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
