BluegrassBill
Jun 10, 2014Explorer
Try the normal things first, New sparkplug,fuel filter and air filter. Be sure oil is proper 15-40 wt & clean. If no improvement, Remove Carb bowl. Check for water in bowl and clean. (Carb is non re-buildable). Try Carb Spray while running. Next disconnect fuel line and mix 1/2 can of Seafoam carb cleaner in 1 gal fuel and run directly into genset. If non of these things fix problems then new carb is next $$$$$. Keep us posted on outcome. Bill
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
