vacuumbed
Nov 03, 2013Explorer
Generator Jim wrote:
134 vac is a little high. If you have a frequency (Hertz) meter, connect it across the 120 volts and adjust the governor speed spring on top of the cooling fan for 62 at no load and 58 at full load. Your voltage should be within tolerances at that point.
JimL
Scott and Sherrie -- where have you been, I missed you.
I don't have don't have one of these meters, is there a workaround? When I first fired it the voltage was at 124 and very slowly went up to 134 over 3-4 minutes time as the engine warmed up.
