bounder39zman
Mar 06, 2023Explorer II
Mr Wizard's info is pretty much correct. If you are getting 20vac at 30amp gen receptacle, then most likely a "field" problem. Even at only 200 hrs, the field brushes might be sticking in the holder, or the slip rings are oxidized or dirty. possibly a control board going bad, as the field (voltage regulation) is part of the control board. Unfortunately, brushes/slip rings are not easily accessible, as they are located behind fan/flywheel assembly. there are troubleshooting procedures to determine problem, but some specialized test equipment needed. BTW, no low oil level switch is used on this spec 4KY.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
