NRALIFR
Apr 19, 2021Explorer
The possibility of a leak exists in any engine, or any type. So therefore you should never use synthetic oil in any engine. :R
I have to wonder about the advice given by some of these so-called experts. Full synthetic oils are clearly superior to conventional oils. This isn’t even debatable. At both low and high temperatures, synthetic oils have better viscosity and thermal stability than conventional oil or synthetic blends. Full synthetic oils are designed to flow quickly in winter temperatures and resist extreme heat. So now the “experts” are advising that we not use it because it “might leak”. Maybe I should just start using an old fashioned non-detergent oil so a healthy layer of sludge can build up on the inside, and help prevent future leaks.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
