dougrainer
Apr 19, 2021Nomad
NRALIFR wrote:
The possibility of a leak exists in any engine, or any type. So therefore you should never use synthetic oil in any engine. :R
I have to wonder about the advice given by some of these so-called experts. Full synthetic oils are clearly superior to conventional oils. This isn’t even debatable. At both low and high temperatures, synthetic oils have better viscosity and thermal stability than conventional oil or synthetic blends. Full synthetic oils are designed to flow quickly in winter temperatures and resist extreme heat. So now the “experts” are advising that we not use it because it “might leak”. Maybe I should just start using an old fashioned non-detergent oil so a healthy layer of sludge can build up on the inside, and help prevent future leaks.
If you are using my post for this post. READ it again. What the Mobile engineer stated was, in a "used" engine it is not advisable to start using Synthetic oil. In a NEW engine, continue using Synthetic oil. IF your NEW engine does not have Synthetic oil then use it at the first Oil Change. All my Vehicles except my 1075 Corvette came with Synthetic and I use Synthetic for replacement. I change the OIL FILTER every 5K and do NOT change the Synthetic oil at that time. I change the Synthetic OIL every 10k. I could go longer, but I am old school and feel better at 10k. Remember Mobil 1 was touted as a 25k life oil 40 years ago. Oil Filters are there to trap the contaminants that are produced from Metal on Metal to prevent them from circulating thru the Engine. Which will cause problems if allowed to circulate. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
