says take to repair shop.any idea how expensive repairs for this might be?should I just look into buying new generator for motorhome? serial #4KYFA26100K
Quote " right now there is only 1/4 of a tank in the coach so I need to fill it up just to rule that out". That could very well be your problem, The generator fuel pickup is usually at the 1/4 mark to prevent using all the fuel in your tank, so you will be able to drive. Its probably just starting to suck air in and then starving the generator. Try more gas first, cheapest option.
Ken
