DrewE
Mar 30, 2018Explorer III
We can't see your images (they're sitting on your own computer, not online somewhere), but I think probably the wires you're talking about are the AC power output wires from the generator. There's a chance there's a junction box somewhere on the motorhome not too far from the generator where they could be unhooked.
I'd avoid cutting them randomly; to splice them safely and legally, you'd need to have the splice enclosed in an electrical box (per the NEC), and if it's exposed to the elements or road spray it should be a weathertight box with appropriate weathertight wiring.
On my Onan of that model, albeit quite a few years older, the neutral and ground connect to a little star shaped thingy inside the generator opposite the 12V ground wire connection (that, indeed, the 12V ground wire is bolted up to). The hot wire snakes across the bottom and connects to the AC circuit breaker. To get to them, it was necessary to remove the starter solenoid and control circuit modules from the left side and to at least partly disassemble the control panel unit on the right side. A torx screwdriver of the appropriate size was about the only tool required, but it did take a bit of labor and poking around in slightly tight corners.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
