cgmartine
Apr 01, 2018Explorer
I Have a K series generator that I removed just a couple of months ago. I used a motorcycle jack, which made it quite easy. As for the wires, I found out that they should be taken off at the junction box. There is no other way, since they are part of a wire loom that goes to another part of the generator, so don't pull on that end of the wires too hard. Make sure you also remove the muffler before you lower it, otherwise you will crush it. The mechanic will probably thank you, since it is sometimes a tedious job. He can also bench test the generator easier once it is out and can supply it with gas from a gas can. In fact, my son and I lifted the generator and placed it in the truck of our car and took it home to my garage. I had my generator running in my garage. It is not as bulky or heavy as it seems.
