wolfe10
Jun 27, 2016Explorer
Let me slightly restate that:
A liquid LP generator WILL run just fine on HIGH PRESSURE VAPOR (i.e. "T" off before vapor regulator that supplies the house appliances. Have many hours of running a Liquid LP Onan like this after in-depth discussions with engineers at Marshall Gas and Onan. And, while you could still get contaminates leaching from the hose, you will NOT get any long-chain hydrocarbon contaminates from the propane, as those do not vaporize.
Agree, if you are supplying it with vapor downstream of the regulator (i.e. under 1 PSI of pressure) it will not work without modification.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
